Home Automation
n3qik
Solar Expert Posts: 741 ✭✭
With 10+ inches of snow on the panels, I placed the PV system off line. This is a good time to make upgrades. I am incorporating the PV system into a home automation system.
My goal is to combine the PV system and TED 1001, then add security, data logging, plus more.
The main component is an Advantech Adam 5000, Link: http://www.advantech.com/products/ADAM-5000-Series/sub_1-368QR0.aspx
As an industrial device, it is very flexible to meet my current and future needs.
I have just started, as such, some of the software/hardware is missing or non-working. Currently working is Heater in the HVAC Systems tab and battery Volts in the Power systems tab.
Here is a live view: http://71.59.85.35:5800/
Re: Home Automation
nice! what are your solar system specs? I guess you are content with it to be heading in this direction now. looks like it will be intresting to deal with. I'd make sure I could still operate everyhing manually to though.
BTW that link only shows a "tightVNC" link/url, no data.
thats cool! keep us updated. -
Re: Home Automationnotsobright wrote: »
I get that at times, I must restart Firefox. Looks like a Java thing. -
Re: Home Automation
What is working as of 2-26-2010. Best to look at between 10AM to 3PM EST.
Power System Tab:
Solar Power/Solar Dump Load Block- Everything.
Grid Power Block- L1/L2 Volts only.
Status Block- Everything.
Battery Charge State Block- Everything.
History Button- Solar 24 Hour Graft only.
HVAC System Tab:
Heater Block- Everything.
Air Conditioning- None
Timer Setup Button- None
Environment Tab:
Basement temp. only.
Security System:
Night Lights only. -
Re: Home Automation
12.5 volts for your battery bank? May be under -0.5 amp load...
Re: Home Automation
Currently have a battery charger holding the voltage at about 12.5-12.7 volts. -
Re: Home Automation
Ken, I think this is impressive work. Nice job!
Best regards,
Bill -
Re: Home AutomationKen, I think this is impressive work. Nice job!
X2
Ken what is your web based display software that you are using? Did you write it yourself? -
Re: Home Automation
Wow that's really nice how the software is layed out.
How much is the equipment cost for the same thing you have there? -
Re: Home Automation
mikeo-
I am using TightVNC. Very nice free software for remote control/viewing.
RWB-
I am at about $2100.00. Could have done it for about $1500.00 or less. Found out I did not need to buy some stuff.
Rest-
Thanks!!!! Work is still in progress.
- 621 Discussion Forums/Café
