How can a 24v win-gen help charge a 48v battery bank?
BilljustBill
Solar Expert Posts: 219 ✭✭✭
There is a possibility I can get a 700 watt win-gen that charges at either 12v or 24v, but the system I plan is using an 800 watts of PV panels and a 1500 watt Aims SWInverter is 48 volts...
Is there any way to use a 24v win-gen to aid in charging a 48v battery bank?
Bill
Bill
Bill
Re: How can a 24v win-gen help charge a 48v battery bank?
the factory may have jumper settings. There are not many 48v wind machines - I've got half an eye looking for one, but nothing i've liked yet.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
No practical way, no. There are boost converters available, but they are very expensive and hard to find one that will work with the choppy output of a wind turbine.
