Powering small LED spot light?
I have a LED spot light that was being run by a 12V 5AH lead acid battery. There was a board that both charged the battery and powered the lights through a PT4115 LED driver. Near as I can figure from the sensing resistors, it was supplying 606ma to the light.
The light has 36 large LEDs. There are 12 rows in parallel of 3 LEDs in series. I don't know anything else about the LEDs.
The board has since fried. I though I would resurrect the parts and pieces and build my own solar lighting system.
What us the most efficient off the shelf driver I can use for this light? I would really rather have an off the shelf pre built driver like a buck puck. I don't really want to build up a regulator from the chip level if I can avoid it.
What is the most efficient charge controller for this setup?
Small. efficient and reasonably inexpensive are the keys here.
Re: Powering small LED spot light?
I would take a look at these guys:
Sandwich Shoppe LED Converters
I have never done business with them--but they have been around a reasonable time building parts to modify flashlights to LEDs.
They also have a forum for discussion of their products:
CandelPowerForums: Sandwich Shoppe
How much does one of these cost ? The entire unit.
Might not be worth replacing parts.Nature's Design & Green Energy on FaceBook : Stop by and "Like" us anytime.. Many up-to-date articles about Renewables every day.
Lots of DIY Renewable Energy Projects on ETSY : Solar Panel builds, Wind Turbine builds, Rain Barrel build,etc. -
You are probably right but it is a challenge and I get something that works the way I want it to work.GreenPowerManiac wrote: »How much does one of these cost ? The entire unit.
Might not be worth replacing parts. -
My wife hates this fact: When I'm bored, I'll find a way to spend her money while she works, and that means having to fix things that are better off replaced than repaired !
Good luck with your adventure and spend a lot of money !Nature's Design & Green Energy on FaceBook : Stop by and "Like" us anytime.. Many up-to-date articles about Renewables every day.
- 425 Caravan, Recreational Vehicle, and Marine Power Systems
- 651 Solar Water Pumping
- 611 Discussion Forums/Café
