Music Equipment
TOMMYB1
Registered Users Posts: 6 ✭
Our band is doing a lot of out door gigs and I was wondering what size solar panel would I need to be able to use our equipment? I'm a total newbie at this.
But we keep having to many problems with the generators that we have and I was hoping solar system might work. Any help would be appreciated .
TOMMYB1
TOMMYB1
Re: Music Equipment
well to start with what equipment are you using/?
guitar amp? s ?
bass guitar amp?
keyboards?
electronic drums?
foldback amps ?rated output
foldback mixer?channels?
FOH mixer ?channels?
FOH amps? rated output?
Drum sidefill amps?
Lighting? type? par 64s?
Laser light?
Duration of one show?
time of show. midday start ? late afternoon start?
aprox budget for solar panels, batteries ,charger . inverters??
trucK capacity for carrying batteries. batteries are HEAVY -
Re: Music Equipment
Before I start quoting The Who ...:p
Forget it. If your band uses amps they will eat up more power than you can imagine. Lights? Another huge power drain.
If you want to get specific, get a Kill-A-Watt meter (or similar) and plug an amp into it. Play for an hour and see how many Watts run up. I used to have a 300 Watt, four-channel amp. If I tried to run that off my solar electric system today it would kill the batteries in a couple of hours.
I'm not saying it can't be done, but the cost involved would be enormous. -
Re: Music Equipment
OK! Thanks for the info. I knew there was a lot of power needed . Was hoping for the best . thanks again . TOMMYB1 -
Re: Music Equipment
Yeah we're using most of that equipment and more . Thanks, TOMMYB1 -
Re: Music Equipment
Yea, forget solar for a band. Even a small jazz trio working a wedding would require enough solar panels to cover a garage roof.
Figure out how much amps (as in amperage) you need, then get a good quiet generator like a Honda EU3000 or a EU6500 (for a rock band, even bigger). -
Re: Music Equipment
There's no reason why you couldn't run the simple things from Solar. Lighting and laser lights may not take much power. If for some reason people know you're a "Green" band, might gain those popular votes.Nature's Design & Green Energy on FaceBook : Stop by and "Like" us anytime.. Many up-to-date articles about Renewables every day.
Lots of DIY Renewable Energy Projects on ETSY : Solar Panel builds, Wind Turbine builds, Rain Barrel build,etc. -
Re: Music Equipment
par64 s the most used light in existance for bands draw 1000 watts each. most small bands would be using at least 12 of them thats a rather large 12,000 watts A rather huge solar array would be needed for that. -
Re: Music Equipment
No, No, No.... The simple stuff: LED lighting, track lighting, borders, small illuminated signs, everything that makes people believe that it's renewable energy. Example: A sign that says, "Powered by 5% Renewable Energy". Doesn't have to be extensive....Nature's Design & Green Energy on FaceBook : Stop by and "Like" us anytime.. Many up-to-date articles about Renewables every day.
Re: Music Equipment
Wow! İmpressive! Powered by 5 whole percent solar and İ guess some green fools might be impressed but most of us are going to laugh. -
Re: Music Equipment
I think Costco has a whole system for $199."we go where power lines don't" Sierra Nevada mountain area
Re: Music Equipment
Its an outdoors system the band is using,They are not a flute and banjo duo in Joe,s pizza and shoe shine shop.:cool: -
Re: Music Equipment
Biodiesel and buying solar RE credits is about the only useful way for a touring band to truly be "green".
There are a few real green advantages as a genset running biodiesel can be less of an environmental spill hazard... However, the processing (if done at home) can have its own issues.
One big issue with biodiesel are fuel taxes. I know that states and federal government are really "interested" in collecting road taxes (dyed vs un-dyed fuel, etc.)--Not sure if un-taxed generator fuel would attract any attention though.
Re: Music Equipment
First off you absolutely have to go to an inverter generator. Most around here like the Honda's but there are other brands out there.
Next look at lighting. OmniSistem makes an LED Par 64 that consumes 18W. You can run a whole bank of these for what a standard can pulls. Nice thing is no gels required. The do require clean sine wave power.
They only sell through dealers. If you don't have a local one drop me a note. I have a friend that handles these. -
Re: Music Equipment
If you're a techno/industrial band you could run a Lister 6/1 engine on pure vegetable oil and it could be part of your sound
Heck if you connected it to a DC generator you could vary the beat for different songs. -
Re: Music Equipment
Have you ever seen the output of one of these cans? in a very small room with about 20 of them they will just about light up a stage with nice soft lighting. 20 of them would not ever put out the raw power of one real 1000w par64.AS for outdor use LED 64,s would be less than useless.as there is no "beam of light from them" Its the hard "spotlight" effect that makes the real par 64 so useful -
Re: Music Equipment
You might be surprised.
A couple of club stages near me use them, it is how I found out about them. I would not recommend them for a big outdoor venue, but small scale they are great. -
Re: Music Equipment
A couple of club stages near me use them, it is how I found out about them. I would not recommend them for a big outdoor venue, but small scale they are great. __________________
Ihave seen them in use here on a very small stage for a single singer /guitarist and yes were ok. but for big indoor stage for a rock band the lighting is just too subdued, rock bands need intense lighting Second major problem they cant be used with a normal desk and power rack . as they have no provision to control the 3 sets of colour LEDs.. The control desk and power rack that comes with the LED 64s is only 4 channels..
The person asking in the first post about running their band from solar was obviously doing an outdoor event and the only suitable lights are really "real" par64s and running them from solar is just about impossible unless you have a truck load of batteries and a few thousand sqft of solar panels -
Re: Music EquipmentIf you're a techno/industrial band you could run a Lister 6/1 engine on pure vegetable oil and it could be part of your sound
Okay...having been both a musician and a sound engineer in a past life*...
I LOVE THIS IDEA!
Nuff said.
* Well, no so long ago I guess...the last gig of that type I did was in 2006 when I did a complete rebuild on the sound system at a Carson City, NV nightclub called "NV50".
http://www.myspace.com/nvfifty
- 226 Forum & Website
- 617 Discussion Forums/Café
