Battery loses significant power shortly after dark
I recently bought an new travel trailer and the dealer transfered my solar panel and controller to the new trailer. Since then I have noticed that shortly after dark the battery level drops from excellent to good with no lighting or anything of significance drawing a charge. One night I disconnected the charger from the batteries and the batteries seemed to stay charged better. Could there be a simple connection issue I could resolve to correct this problem. I also notice that the trailers battery indicator doesn't agree with the charge controller indicator, the trailer indicator showing considerably more charge.
I have a 75watt panel a Specialty Concepts Mark 15 controller and a single Kentics HC 2000 glass mat battery.
Re: Battery loses significant power shortly after dark
A wild guess: since your controller disconnected left your batteries in a good state, vs connected after dark, did your dealer perhaps ew-connect your panel without using the blocking diode? -
Not to be too dumb but how would I verify and correct that?
Thanks -
Where you are reading that level drop from? If you are using one of those generic good-fair-bad type meters without an actual voltage reading, it may not mean much. -
I'm only looking at the readings on the controller and on the campers battery level indicator. I'm on the road and don't have a real meter with me. -
You will need a good DVM/DMM (digital volt/multi meter) to confirm.
Also, you can read about the care and feeding of lead battery banks here:
www.batteryfaq.org
Deep Cycle Battery FAQ
If you have a battery charge controller (even an inexpensive one), you should not need a blocking diode anywhere. For systems with a solar panel connected to a battery -- the solar panels do bleed back current at night and a blocking diode prevents the self discharge.
I should also add that most people terribly overestimate the amount of power that a solar panel can provide and underestimate the amount of power their loads consume.
Depending on where you are at and the weather--you may get 2-3 hours of full sun equivalent per day. The charger + battery controller + inverter (if you are using one) are roughly 50% - 60% efficient for the typical system.- 75 watts * 2 hours of sun * 0.50 = 75 Watt*Hours of charge in winter
- 75 WH * 1/4 hours * 1/12 volt battery = 1.6 amps average load
- 1.6 amps * 12 volts = 19 watt average load
I think Bill has it about right. I would suspect the led on the controllers are pretty arbitrary. I have used the same controller before, and if memory serves the leds go to yellow with any load at all, battery voltage ~12.5 or so.
I also think that the campers battery level meter is probably very inaccurate. I would fully charge the battery with shore/genny power sooner than later to prevent any further damage,and then watch it for a few days while you travel and see how it reacts.
Tony -
That model of charge controller is pretty ancient - first designed in the late 70's with some changes in the late 80's. Relay based on-off controller, so there could be some significant voltage drops when the panel is shut off.
- 621 Discussion Forums/Café
