Battery loses significant power shortly after dark
I recently bought an new travel trailer and the dealer transfered my solar panel and controller to the new trailer. Since then I have noticed that shortly after dark the battery level drops from excellent to good with no lighting or anything of significance drawing a charge. One night I disconnected the charger from the batteries and the batteries seemed to stay charged better. Could there be a simple connection issue I could resolve to correct this problem. I also notice that the trailers battery indicator doesn't agree with the charge controller indicator, the trailer indicator showing considerably more charge.
I have a 75watt panel a Specialty Concepts Mark 15 controller and a single Kentics HC 2000 glass mat battery.
  • Sheldon
    Sheldon Solar Expert Posts: 51 ✭✭✭✭
    Re: Battery loses significant power shortly after dark
    A wild guess: since your controller disconnected left your batteries in a good state, vs connected after dark, did your dealer perhaps ew-connect your panel without using the blocking diode?
  • System2
    System2 Posts: 6,290 admin
    Not to be too dumb but how would I verify and correct that?
  • Windsun
    Where you are reading that level drop from? If you are using one of those generic good-fair-bad type meters without an actual voltage reading, it may not mean much.
  • System2
    I'm only looking at the readings on the controller and on the campers battery level indicator. I'm on the road and don't have a real meter with me.
    BB. Super Moderators, Administrators Posts: 33,688 admin
    You will need a good DVM/DMM (digital volt/multi meter) to confirm.
    Also, you can read about the care and feeding of lead battery banks here:
    www.batteryfaq.org
    Deep Cycle Battery FAQ
    If you have a battery charge controller (even an inexpensive one), you should not need a blocking diode anywhere. For systems with a solar panel connected to a battery -- the solar panels do bleed back current at night and a blocking diode prevents the self discharge.
    I should also add that most people terribly overestimate the amount of power that a solar panel can provide and underestimate the amount of power their loads consume.
    Depending on where you are at and the weather--you may get 2-3 hours of full sun equivalent per day. The charger + battery controller + inverter (if you are using one) are roughly 50% - 60% efficient for the typical system.
    • 75 watts * 2 hours of sun * 0.50 = 75 Watt*Hours of charge in winter
    75 Watt*Hours, say you use power for 4 hours an evening (computer, lights, etc.) works out to:
    • 75 WH * 1/4 hours * 1/12 volt battery = 1.6 amps average load
    • 1.6 amps * 12 volts = 19 watt average load
    This leads to "deficit charging" or constantly running the storage battery mostly discharged/deep discharging. Wears out the battery fairly quickly (a few hundred charging cycles) and ages them quicker to (sulfates hardening).
  • icarus
    I think Bill has it about right. I would suspect the led on the controllers are pretty arbitrary. I have used the same controller before, and if memory serves the leds go to yellow with any load at all, battery voltage ~12.5 or so.
    I also think that the campers battery level meter is probably very inaccurate. I would fully charge the battery with shore/genny power sooner than later to prevent any further damage,and then watch it for a few days while you travel and see how it reacts.
  • Windsun
    That model of charge controller is pretty ancient - first designed in the late 70's with some changes in the late 80's. Relay based on-off controller, so there could be some significant voltage drops when the panel is shut off.
