unbeleivable use of engineering and electrical power
westbranch
Solar Expert Posts: 5,183 ✭✭✭✭
for these cold snowy winter days..
THIS IS UNBELIEVABLE. WHAT AN INVENTION.
Read before playing!
Turn your sound on for this. Read this first, then watch.
This is almost unbelievable. See how all of the balls wind up in catcher cones. Not one ball hits the ground.
Even those hitting the drums bounce into catcher cones to be shot out at yet another instrument.
This incredible machine was built as a collaborative effort between the Robert M. Trammell Music
Conservatory and the Sharon Wick School of Engineering at the University of Iowa ..
Amazingly, 97% of the machines components came from John Deere Industries and Irrigation Equipment
of Bancroft , Iowa ......Yes, farm equipment!
It took the team a combined 13,029 hours of set-up, alignment, calibration, and tuning before filming this
video but as you can see it was WELL worth the effort.
It is now on display in the Matthew Gerhard Alumni Hall at the University and is already slated to be donated to the Smithsonian.
http://www.youtube.com/watch?v=gaQYb4Ykhz8
enjoy
Eric
enjoy
Eric
Re: unbeleivable use of engineering and electrical power
http://www.snopes.com/photos/arts/musicmachine.asp
Bogus - computer animationPowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Sorry Eric,
This has been around a bit, Mike is right, it is animated,, not real.
Tony -
the public broadcasting system has been airing those for quite some time and are computer generated, but something to watch none the less.
