Sump pump D/C kit
GreenPowerManiac
Solar Expert Posts: 453 ✭✭✭
I'm thinking about going Solar with my sump pump.
Would consist of:
1) 72 watt solar panel
2) Charge Controller
3) 1 - Deep Cycle Battery 100Ahs
4) D/C sump pump
Is this all I need besides the wiring and mounting ?
Now my pump is running on A/C. Can it be converted to D/C
Brand name: Zoeller Co.
May draw a few amps when running for a few seconds. It only runs for a few seconds every minute during heavy soaking rains. And will run this way for a couple days more. 11-3/4 months out of the year it does nothing.
Would consist of:
4) D/C sump pump
Re: Sump pump D/C kit
First:
What is the size (HP) or Watts, of the pump. You need an inverter that can manage to reliably start it at 3am, after a dozen other starts.
2nd:
Is it in a pit? Room for a 2nd pump?
Is your AC power reliable ?
Could a 12VDC boat bilge pump work with the amount of lift you have?
Go with a battery, and just use a smart wall charger, skip the solar panelPowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Most AC sump pump are 1/4 to 1/3 HP and thus really heavy power users for solar. There are alternatives;
http://www.canadiantire.ca/AST/browse/8/KitchenBath/Plumbing/WaterPumps/PRD~0623549P/Mastercraft%2BSump%2BPump%2BBattery%2BBackup.jsp
(Flotec - ought to be available locally in your area).
http://www.canadiantire.ca/AST/browse/8/KitchenBath/Plumbing/WaterPumps/PRD~0623508P/Emergency%2BSump%2BPump%2B%2528SUMP%2BBUDDY%2529.jsp
(I've no experience with these, but should work on "city" water if the pumping need is not too high.)
Or you can put together a "battery back-up" system charged from mains - no solar panels. Panels don't put out much power when it rains, and sumps tend not to need to run when it's sunny.
How about using a Rule 12 vdc bulge pump with either an electronic or float switch?
They draw ~5 amps, move ~3 gmp up to ~10' if memory serves, they are cheap to buy >$50. You could wire two or even three of them, install them at various levels in the sump so with lots of water they all run, when the water drops, only two run, and finally at the bottom just one runs. The will also handle a fair bit of trash.
http://www.rule-industries.com/products/pumps/bilge_pumps/index.htm -
http://www.tractorsupply.com/home-improvement/water-pumps/sump-pumps/shur-dri-reg-12-volt-battery-back-up-sump-pump-system-3123027
This is what I am using, I've just wired it to my PV battery system, and mounted the sump controller to the side of my battery box. Been using for a few months with no issue! -
Slappy,
I've seen this idea and looks promising, however I'd still like to hook up a panel to the battery for charging and leave the charger off. Some charge during a rainy day is better than nothing when the power is out.
It's in a pit and I believe it's a 1/4 hp. It's rather small. Max uplift is 8' .Nature's Design & Green Energy on FaceBook : Stop by and "Like" us anytime.. Many up-to-date articles about Renewables every day.
Lots of DIY Renewable Energy Projects on ETSY : Solar Panel builds, Wind Turbine builds, Rain Barrel build,etc. -
Re: Sump pump D/C kitGreenPowerManiac wrote: »Slappy,
I'd go with a pair of marine bilge pumps. They can handle 8', can have integral float switches, and run right off a battery. even 1/4 hp motor is tough for a inverter, and you don't want to risk the basement and all the goodies.
Put one pump on a brick, and you have a totally redundant system till the battery goes dead.
1500 Bilge Pump (12 VDC) 1500 GPH
http://legacy.shurflo.com/pdf/Marine/product_data_sheets/Bilge%20Pumps/pds-358-000-00.pdf
7A, 1,400 GPH @ 8'Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
The shurflo pumps are virtual clones of the Rules that I mentioned earlier. Either or,,,.
I suspect that the Rules might be a bit cheaper since they are all over the net, and marine supply stores such as boaters world.
- 232 Forum & Website
