Pond pump selection
mike95490
Solar Expert Posts: 9,583 ✭✭✭✭✭
I win the bad timing of the year award
Too early for the Morningstar MPPT 60A
Too late for Dankoff
[Conergy has discontinued all of the solar (ex-Dankoff) water pumps as of Sept 2009.]
And the funds in my 401K
I'm looking for a DC or AC trash pump, I can "float" about 2' underwater in a pond, and pump up about 30' of lift to a storage tank where a float switch will be. I only need a couple (1-3) of GPM, and some of the $1,500 pumps seem like overkill. Boat bilge pumps don't have enough lift.
Suggestions?
Suggestions?
Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048
inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A
NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole |
Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor
(1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: Pond pump selection
And most of the smaller pumps, like the submersible and Shurflo surface pumps clog up with debris and pond scums and bugs etc pretty fast.
We are looking around for something to replace the Dankoff/Conergy, but not much available in the mid to low price range. -
Lorentz? http://www.lorentz.de/offgrid/en/products/surfacepumps/boost
(No idea about price) -
Look at a marine impeller pumps for boats. Jabsco will pump to the top of the mast. Not very good with power but it will suck in sea weed/fish and spit it out. around $200...."we go where power lines don't" Sierra Nevada mountain area
