positive grounding
has anybody have an Idea how to do positive ground on a grid tie installation?
or does anybody know what to do when you have positive ground your panels?
    Re: positive grounding
    The major GT Inverter Manufacturers do the "panel grounding" for you...
    Xantrex, you order the positive ground option (they stuff the ground fault detection fuse holder in a different location and probably a configuration jumper change by the factory).
    Fronius, you just move the fuse to a different holder and move a jumper or two.
    You do not "ground" the array yourself through an external jumper--this defeats the ground fault detection circuitry/detection fuse.
    PS: Check the on-line installation manuals for the GT Inverter(s) you are interested in--I am just reciting my limited understanding/from personal memory.
  • newenergy
    newenergy Solar Expert Posts: 291 ✭✭✭✭✭✭
    SMA, also. Just connect the white to the positive. (read the manual of course)
