How can I check my Horrible Freight solar panels?
bgarrett
Solar Expert Posts: 48 ✭
I dont think my panels are working or maybe its the controller.
The voltmeter gives me 18 volts output on the controller and after 49 days on the charger with no load, (I was outatown) the battery has very little charge,
How can I determine what the problem is?
Re: How can I check my Horrible Freight solar panels?
Take the controller out of the circuit. On the other hand, if your battery has been sitting un charged for ~49 days it may be toast. I suggest fully charging the battery before you do anything.
An ammeter and a shunt will tell you how much current the panel is putting out.
Tony -
I usually chuck mine from a bridge, then buy real ones.
Serioulsy though, is the controller any good? Try connecting the panel directly to the battery [ +to +, - to - ] and check the battery voltage every 30 minutes, you should see the battery charge come up slowly, if you have a meter.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Assuming the volt meter is calibrated:- What is the voltage on the panel side of the charge controller (full sun)
- What is the voltage on the battery side of the charge controller (full sun)
- Set the Meter to 10 amps maximum scale, disconnect the solar panel, put the meter across solar panel output leads (the amp meter will short the output of the panel--but that is OK. DO NOT SHORT CIRCUIT THE BATTERY--that will ruin the meter--or worse). The maximum Isc (short circuit current) should be around Imp +/- depending on the actual amount of sun at the time.
- Last test, with the meter set to 10 amp scale, connect the panel directly to the battery and measure the charging current (make sure the panel/battery polarity is correct--you will fry the meter+panels if wrong). Should be close to Imp (if full sun).
What Bill says, assuming you have meter capable of handling DC amps. (Most cheap ones will only handle Milliamps).
Tony -
Gee, that is the first complaint we have heard of those panels... today
Actually it is usually the $7 controller that goes out, if your panels are OK with the tests given by others, you can just buy a small Morningstar, such as http://store.solar-electric.com/ss-6.html -
When I first set up my HF panels, I found that the supplied charge controller (newer one, with LED digital readout) does NOT block current flow at night. The panels also didn't have diodes in them, so when the sun went down the battery started to discharge through the panels.
I just chucked the controller and bought a decent one from NAWS.
Not sure that would cause enough discharge to kill the battery, IIRC it wasn't a very large current, but don't remember for sure... -
Must have gotten one of the few that worked for the most part. 6 panels into one of the digital controllers into 110AH of batteries. Worked, just had to up the fuse size. Mine did block the battery at night.
Now with a reading of 18 volts. The battery is WAY over charger/shot/bad. Look at getting a new charge controller and battery.
Now to check the panels, there are two test:
Open voltage- this is with a meter set to read 200 VDC. Hook red probe to the red wire and the black probe to the black wire. In full sun you should read 19-22 volts.
Short circuit current- this is with a meter set to read 10 amps. Hook red probe to the red wire and the black probe to the black wire. In full sun you should read 1-2 amps. I forgot the exact reading. -
I have one on my RV with there controller and everything has worked 100%, I love that thing! (maybe I'm lucky?) -
Re: How can I check my Horrible Freight solar panels?I have one on my RV with there controller and everything has worked 100%, I love that thing! (maybe I'm lucky?)
You've just not asked it to live up to the somewhat fantastic claims made by the retailer.:D
- 232 Forum & Website
