which battery charger?
bgarrett
Solar Expert Posts: 48 ✭
I have been reading this forum for a while and did a search but I do not see much on which battery charger is good to use with my generator to charge my batteries.
Which charger do you think is best?
Re: which battery charger?
The answer of course depends to a great extent on what battery (ies) you have, how many you have and how you use them.
Tony -
I prefer a solar generator (PV panels), but what I will end up using is a Frankenstein arrangement of 2 manual start generators:
1) Honeywell 2000 inverter type into a Iota 48V, 15A battery charger
2) Lister type 6/1 engine, 3KW gen, into the XW6048 internal chargerPowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
