BP panels darkening
Robert Lake
Registered Users Posts: 9 ✭
My BP panels, of 10 years now, are darkening. This concerns me but I have not done an electrical check yet to determine if there is significant loss or not. Has anyone else reun into this problem wqith BP panels?
Re: BP panels darkening
Check the output.
If the output is good (which I would suspect it is)I wouldn't worry about it.
Tony -
i'd be curious to know how it is you know they are darkening after 10 years?
as was said, if they still work as they should, who cares? -
Mine darken at the edges (close to 4 years now) and look like "classic" bad panels... Turns out, that washing with soap and water (not just water and brush) removes the stain (probably "oak leaf tea" for my panels).
what type of soap are you talking here, dish soap? -
I believe it was a Turtle Wax product (could have been Windex)--it was a soap dispenser that fit on the end of a hose (intended for washing window). I would try whatever I had handy
My array is on a 2nd story roof and difficult to access--so I don't do it often. And I wanted a hose dispenser to make application a bit easier.
Are the cells them self "darkening" my 30 year old french Photowatt panels show their age with the fine silver(tined copper?) leads turning dark from the outer edges in.Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
