Sunnyboy 1800U (120V?)
SolarEpiphany
Registered Users Posts: 5 ✭
This is the first time i've installed a 120V Sunnyboy. The array is 1.6kW. Seems a little much to be putting on one leg of a panel. Anyone have experience? Also, the run is close to 100', voltage drop will be higher than with 240.
Re: Sunnyboy 1800U (120V?)
oK actually, maybe we won't be specifying the sunnyboy 1800. My distributors have discontinued them. There aren't really ANY string inverters available under 2-3kW are there?? -
Xantrex GT2.5 is the smallest I know of , price wise is is less than the SMA 1800 unit -
You may want to check out the Kaco 1501x Blue Planet string inverter. Rated at 1501W. There is a distributor I have worked with in the past called Krannich Solar in NJ that carries the Kaco brand. Don't know if NAWS carries them.
Al
