DC timer to turn a couple of lights on
Still learning
Registered Users Posts: 18 ✭
I have been looking around for a friend of mine that needs to be able to turn a few lights on down in his shed, and they need to be on a timer, ac timers are everywhere but I can't locate any dc timers. Not sure if they even make them. Would someone know where he might be able to locate one.
Re: DC timer to turn a couple of lights onStill learning wrote: »I can't locate any dc timers. Not sure if they even make them. Would someone know where he might be able to locate one.
Here's a good one that's inexpensive:
http://www.thecybershack.com/mm5/merchant.mvc?Screen=PROD&Store_Code=WTFS&Product_Code=REDNEK&Category_Code=TIMR -
And here is a more high-end timer (requires 12 vdc for timing, can control up to 240 VAC).
The other option (or in addition to a timer) could be a 12 VDC motion detector (say animals walking into a barn at night--motion detector on when stock moving in, timer to turn off after feeding time).
I have been using an intermatic timer I bought from Home Depot to switch all sorts of loads. It basically is an electronic timer that runs from the internal battery and flips a small latching relay on or off. It fits in a regular single gang wall box, but sticks out a bit. I even have one powering a 12v contactor that switches 30 amps at 240v. I haven’t had an issue with them yet...
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/in-wall%20timers/st01c.aspx3kw solar PV, 4 LiFePO4 100a, xw 6048, Honda eu2000i, iota DLS-54-13, Tesla 3, Leaf, Volt, 4 ton horizontal geothermal, grid tied - Green Bay, WI
- 621 Discussion Forums/Café
