will this replace batteries in solar systems?
bgarrett
Solar Expert Posts: 48 ✭
Re: will this replace batteries in solar systems?
When I can buy one at NAWS or it's functional equivalent, then it MIGHT replace batteries. I wouldn't sell yours yet,
Tony -
Sounds like a leak to keep the market going. Dick will read that, and know exactly who he taked to. Bye bye friendship - or hello investors?Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Hello investors ... -
Whenever you see a headline like "Super Secretive Supercapacitor CEO Tells All in Leaked Phone Call", the word that immediately leaps to mind is "hype".
I'll believe it when I see it on the retail shelf, and not one minute before. Some of us are still waiting for our flying cars. -
Still waiting for your flying car?? it be available 1949.. if you have not received it by then you become eligible for either full refund or you can put your name on a priority list for the gas turbine car that will be available 1958..
And super secret super capacitors will be available at Wall mart "very soon" just ask the cleaning supervisor for the form to fill out.... If yoy tell him "the boss "Bugsy " sent you that will speed things up for you.. -
they had time traveling cars, but delorean went out of business.:p -
But Delorean was doing time travel and mabe still is on mouth poppers:roll:
