off grid water pumping Grundfos SQE
toothy
Registered Users Posts: 29 ✭✭✭
Hello all
I have an off grid system and a Grundfos SQE15.
Do any of you know if I would use less power by getting rid of the 301 control box and constant pressure feature, and going with a standard pressure switch and large bladder tank?
I'm not worried about a small amount of power but a substantial savings would be worth doing. I have never had a constant pressure system and it seems like a nice feature.
Thanks in advance
Wade
Thanks in advance
Wade
Re: off grid water pumping Grundfos SQE
The electronic Controller box would use next to nothing power compared to the amps used by the pump. -
Toothy, a more complete description of your system is needed...
You need to compare the constant draw against the periodic draw ... start / stop mose of a conventional pressure tank system.
difficulty is in determining how many times a day you start stop, size of pressure tank etc..
give us more details to help analyze...
Eric
Toothy's original post was from April...
- 231 Forum & Website
