Fuses
I need to replace an 8amp T type fuse. I cannot find an 8 amp, only 6, 10 and higher. Do I need to replace with a time delay? Can I go to 10 amp?
Re: Fuses
What type of equipment is this for. For now, I would use the 6 amp for now. Never hurts to go lower. -
Re: Fuses
Is this the fuse you are looking for?
This appears to be a time delay fuse... Is it for a motor type device with heavy starting load?
I would worry that you may get false trips with a 6 amp T fuse.
If you cannot find a "T" fuse, and can only find a normal delay--you will probably have to go at least once size larger (such as 10 amp) standard blow fuse.
Re: Fuses
225% of full load if time delay fuse, 300% of load if nonetime fuse, as per code in no case should exceed 400% of full load.:cool:
