Battery Need / Requirement
SouthAfrica75
Solar Expert Posts: 36 ✭
I need a battery to power an 8 amp dtv converter box to use in the event of a power outage from a Hurricane
Would need to run it about 5 to max 8 hours a day for probably 3 to 4 day max.
I don't want a battery that is heavy or bulky....
Any suggestions as to what type battery I could get and from where
Re: Battery Need / Requirement
Any battery able to meet your need, as stated, will be heavy and large. Other helpful people on this forum can explain why this is so. BTW, welcome.
Bulky, to me, means large volume/small weight. -
Re: Battery Need / RequirementSouthAfrica75 wrote: »I don't want a battery that is heavy or bulky....
You want the Harry Potter "Infi-spell" Generally, stores are sold out.
You could look into Lithium laptop batteries, but they are very expensive.
So looking at a typical DTV converter box, draws about 30 watts @ 120VAC
8 hours x 4 days = 32 hours Run time (max)
30 w x 115% to allow for inverter losses (Morningstar SureSine @90% eff)
= 35 w consumed @ 12.5V = 2.8A
x 32 hours = 89.6 AH consumed (90Ah)
A typical group 27 deep cycle battery holds 100 AH.
You never want to remove more than 50% of the charge, so you would need
2 , group 27 size, deep cycle batteries (not marine)
These weigh in at about 50 pounds (US) each.
Gives you 200 A storage, 100A useable, and would run a 30W, 120V load for 32 hours, just meeting your spec.
Then you need a way to keep the battery properly charged, and a car battery charger will not do it.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
If that is 8 amps at 12 volts and 50% maximum discharge:
Flooded Cell Lead Acid:
8 amps * 8 hours * 4 days * 1/50% = 512 Amps*Hours @ 12 volts
Crown 6volt 225 AH batteries $125 x 64 lbs:
4 batteries => $500; 256 lbs; 450 AH
If you use an AGM battery, you can discharge to 20% state of charge, and if you assume the minimum power needs (this is a smaller system assuming less hours and days of use):
8 amps * 5 hours * 3 days * 1/80% = 150 Amps*Hours @ 12 volts
Concord AGM batteries PVX-2120L => 1 battery; 212 A*H 138 lbs $483
Or, you can get a small Honda Genset...
eu1000i:Engine: 1.8 HP, Single Cylinder,
Overhead Valve, Air Cooled
Displacement: 50 cc
AC Output: 120V
1000W max.(8.3A)
900W rated (7.5A)
Receptacles: 15A 125V Duplex
NEMA Plug Number: 5-15P
DC Output: 12V, 96W (8A)
Starting System: Recoil
Fuel Tank Capacity: 0.6 gallons
Run Time on One Tankful: 3.8 hrs. @ rated
load--8.3 hrs. @ 1/4 load
Dimensions (L x W x H): 17.7" x 9.4" x 15.0"
Noise Level: 59 dB @ rated load
53 dB @ 1/4 load
Dry Weight: 29 lbs.
Assuming 8 hours * 5 days of generator use:
25% load * 900 watts = 225 watts (vs 8 amps*12 volts = 96 watts)
8 hours * 4 days / 8.3 hours per 0.6 gallons = 2.3 gallons of gasoline
30 lbs for the genset + 2.3 gallons * 6 lb/gal gas = 44 lbs for kit
~$700 USD + $6 of fuel = $706 for kit.
And the generator will provide 2.3x more power (225 watts for 32 hours) vs the biggest system above (96 watts for 32 hours).
You can run a small fridge, and some CFL lighting too in the emergency.
Re: Battery Need / RequirementSouthAfrica75 wrote: »I need a battery to power an 8 amp dtv converter box
dtv = Dish T V or Digital TV set top converter box (USA new standard)?
8A is a LOT of power. 8 watt is more believable.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
OOOppppppsssss
My BAD.... it is 8 watts............ -
Take my 8 amp numbers and divide by 12 ( ).
I assumed that you where including powering a TV and such too.
Re: Battery Need / RequirementTake my 8 amp numbers and divide by 12 ( ).
Bill... Thanks
Actually I only need to power the 8 watt converter box... My portable TV I will run as I have in past Hurricanes with "C" batteries.... I have boxes of those -
You're portable TV may run on batteries,,, but if it is getting signal off the air,, after mid June '09 it won't get a usable signal. If it is off the satellite dish or cable it still will.
I suppose that there are some small DTV portables made nowdays,,, how expensive I don't know.
Tony -
Tony,
They sell $40-$80 DTV converter boxes to allow analog TV's to continue to be operated (don't know if they use channel 3 or require the AV inputs).
I looked around a bit for portable TV's with digital tunners--and they are done in the $200-$110 range now (~7" wide screen or so).
But not a lot of them out there yet--and the digital reception is still a bit of a question. Many users need to use an external whip or amplified "house" antenna for good reception. However--I believe that many TV stations where broadcasting on reduced power for their digital signals until the analog switchover is performed.
I have an older (bigger) converter--is kind of flaky (software needed work, has an issue with the HDMI failing to initialize if the HDTV monitor is not turned on first)--but with a cheap amplified antenna I pickup all my local DTV stations very nicely (have to "rotate" the antenna very accurately--have it sitting on a dresser in our second floor bedroom). Even get one or two that analog is not worth watching on.
Re: Battery Need / RequirementYou're portable TV may run on batteries,,, but if it is getting signal off the air,, after mid June '09 it won't get a usable signal. If it is off the satellite dish or cable it still will.
Tony...... Thanks
I have a DTV converter box that I've connected to the portable TV, it works great..... That's my reason why I'm looking for a battery to run the converter box..... -
You're right,,, I omitted that without a cable connection, or a satellite OR a dtv conversion box,,, analog tv will go dark. Thanks for the clarification,
PS One more phantom load to power 24/7!
- 218 Forum & Website
- 646 Solar Water Pumping
- 813 Wind Power Generation
- 598 Discussion Forums/Café
- 72 Construction
