SOLA Transformer (For Sale)
fooddiva
Registered Users Posts: 15 ✭
We have a SOLA Constant Voltage Transformer that we originally used in our system and replaced many years ago. Does anyone have a use for it? I was going to sale it, but not sure if it is something anyone would have a use for. I even have the manual.
Re: SOLA Transformer (For Sale)
I'd be interested, but shipping from Massachusetts to Calif is a bit pricey. What's the watt specs on the transformer?Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
