Components of Solar Panel
AlbertWhite
Registered Users Posts: 10 ✭
Hey guys,
whats the difference between a panel that comes from the manufacturers and one that you build yourself? also, why do the manufactures cells have greater efficiency and do better?
Re: Components of Solar PanelAlbertWhite wrote: »Hey guys,
You could build a car engine for your car, from parts on ebay. Lots of work, maybe you will skip magnaflux because the seller said it was OK. Build it up, and you find the rings are not right, the carb does not flow, and a bearing in the bottom is bad. Take it apart, fix the bad parts, put it back together, and you find an extra bolt for a main cap. ....
Now the factory built starts to look better and better. They can laminate, impregnate, vacuum seal and sell the bad parts to someone who sells them on ebay. They can buy cheap, the low iron, thin, tempered glass that the local glass shop would charge you $400 for. 2% here, 3% there, it all adds upPowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
so are there any internal parts in the manufactured solar panels that aren't a necessity when building your own...for example a cooling fan or other electrical parts that increase the quality? -
UL Listed
Warranty
Better Output
More Durable
Won't make your insurance company freak out.
Won't freak out the electric company.also, why do the manufactures cells have greater efficiency and do better?
They make batches of cells. They test the cells. Cells that put out enough are used. Any cells that don't measure up (factory seconds) are sold off to someone who puts them on eBay. -
Re: Components of Solar PanelAlbertWhite wrote: »so are there any internal parts in the manufactured solar panels that aren't a necessity when building your own...for example a cooling fan or other electrical parts that increase the quality?
No fans.
Mostly they just have tighter cell spacing, better cell output, better soldering, proper code-approved wire of the proper size, higher vacuum, better seals to hold the vacuum, stronger frames, good glass, UV resistance - just that sort of stuff. -
And, you can see what a home made / junk made panel looks like here:
Panel Fire Question
Build a small one for your experience... Not worth building at home for 1,000 watts worth of panels.
- 621 Discussion Forums/Café
