Any potential in this motor?
dave g
Registered Users Posts: 17 ✭
I have a Bodine Electric Company DC gearmotor. I'm wondering if it has any potential to be used as a generator on a wind turbine. The gear box can be taken off, leaving just the motor.
Specs on the name plate:
Type: 42X5BEPM-E3
No.: T0487056
Volts: 130
Amps: 1.8 DC
HP: 1/4
Duty: Cont.
Ins: A Amb: 40 c
Torq: 135 in/lb
RPM: 33
Ratio: 30/1
Just for grins, I turned it with a drill and measured the voltage: 150 volts at 3,000 RPM, 20 volts at 600 RPM.
Unfortunately, as a gearmotor component, the shaft is a short, small helical gear, and so it would require quite a bit of screwing around to make it suitable for mounting a hub for blades...
Any potential here?
Type: 42X5BEPM-E3
No.: T0487056
Volts: 130
Amps: 1.8 DC
HP: 1/4
Duty: Cont.
Ins: A Amb: 40 c
Torq: 135 in/lb
RPM: 33
Ratio: 30/1
Any potential here?
Re: Any potential in this motor?
Problem is the end bearings. Wind loads can just beat them to death, maybe using a shaft & pillow & thrust bearings, with the prop on it, and a toothed belt (non-slip) can unload the motor bearings.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
What is the RPM of the motor only???
I have a 90V 1750RPM that I had to do a 3:1 overdrive to get it to work. -
Re: Any potential in this motor?What is the RPM of the motor only???
Well, at 33 rpm at the output and 30/1 ratio it would be 990 rpm, right? I've given up on it already - seems like the wrong item in several different ways... And I don't have any place to erect a windmill anyway :-).
What range of speed (rpm) do the rotors on say, 6' diameter wind turbines normally turn? -
I think most look for 200-500 RPMs at the hub.
