Solar Pool Light Works!
joe_danielewicz@msn.com
Registered Users Posts: 6 ✭
I posted in this forum about using four Iridium phone solar charger panels to recharge a deep cycle 12 volt battery.
Well, I finally mounted the panels on a dog house and installed a solar controller and it works! Here's a picture. I changed out the 120V 500W original pool light for a 12V car headlamp and it lights up the pool.
I've also attached a couple of low voltage landscape lights to the controller.
Thanks to this forum for your helpful ideas.
Joe
Joe
Re: Solar Pool Light Works!
keep an eye on your power consumption so that you don't drain too much from the battery. keep a watchful eye on the pvs' ability to keep a charge in the battery as well. -
Niel,
Yes, I'm taking readings morning and night. I notice the battery is at 12.2 V in the afternoon after full day of charging before the lights go on in the evening. This seems to indicate only 60% battery charge.
Perhaps I should take off one of the 4 Watt low voltage landscape lights, and just leave the pool light?
Here's the spec on the Iridium PV panels, four of them connected in series:
Peak Voltage: 3.34 volts
Peak Current: 2.97 Amps
Peak Power: 9.9 Watts
Thanks,
Joe -
Yep, you are pulling more out of the battery, than you are pushing in. Kill the pool light for a couple days, see if your battery has been damaged, or if you can get it to charge up fully. throw a car charger on it for a couple hours.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
