Electrical Engineer allowed to do Electrical work?
hi,m
Have been reading in some other posts and the Electrical Safety Act 2002 that Electrical Engineers are able to carry out household electrical works? IS this true or have I misread the info? Also if this is the case, ie that electrical work can be carried out by an engineer, how does one get a cert of compliance.
Re: Electrical Engineer allowed to do Electrical work?
For what country?
No such act in the US or Canada. -
by a search of that act it seems to have queensland at the top of it.
http://www.legislation.qld.gov.au/LEGISLTN/CURRENT/E/ElectricalSA02.pdf -
WJ has spammed a bunch of forums asking the same question and getting detailed answers...
I did not ban yet--but this is probably a poster from India that posts mildly relevant content and then adds a sig/links to some outsourcing company...
I await to be proved wrong.
In USA, a home owner can do their own work. Still has to pass city inspection though.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
The short answer is NO.
The system is setup as a very closed shop and doesn't seem to allow for any exemptions for professionally qualified engineers - effectively, the only way to obtain a licence is via an apprenticeship.
In my view, the system is well overdue for an overhaul. -
And--surprise--an answer to a question with no country listed (Australian Regulations) by a second Indian from Delhi, with a link to a Seattle Electric Contractor in sig.
Banned and Banned. Lock thread.
-Bill B. (as moderator)Near San Francisco California: 3.5kWatt Grid Tied Solar power system+small backup genset
