Can Solar Power to Drive an Alternator?
I am looking for a way to use solar power to drive a 100KVA generator-Alternator (vs using a diesel engine) order to provide electricity to a small village in Africa. The idea is as follows:
1. Use solar to generate about 4 Kw of electric energy via batteries
2. Use the generated 4KW energy to power an electric motor
3. Boost the RPM via a gear system
4. USe the boosted power to drive an alternator
5. Recharge the batteries via solar
I guess this will probably be more expensive than buying even a 250 KVA generator but the benefit will be that the villagers will not have to spend money on diesel (Since they can't afford the diesel cost in the long run anyway)..
Does this idea seem technically feasible?
HG
  • halfcrazy
    halfcrazy Solar Expert Posts: 720 ✭✭✭
    Re: Can Solar Power to Drive an Alternator?
    NO there is no free lunch if the solar makes 4kw then you only have 4kw period what you describe is perpetual motion.
    BB. Super Moderators, Administrators Posts: 33,714 admin
    Each conversion step resultes in losses:
    Solar to charge controller to battery ~77%
    Battery to load ~80% (~80-90% efficient--depending on battery tech).
    DC load to AC inverter output ~85%
    AC motor ~50% eff
    Alternator+gear train ~50% eff
    0.61*0.77*0.85*0.50*0.50=10% solar panel to DC output efficiency
    VS
    0.77*0.95*0.80=0.59 Solar panel to charge controller to battery to DC load.
    What has worked, as I understand, in Africa was to use batteries for off-peak loads (radios, small computer, etc.), and fire up the genset for evening use for "heavy loads" (lots of lights, fans, cooking, coolers, etc.) + recharging the bank... Much better than running the genset by itself 18 hours per day (for example).
    Running the generator at 25-50%+ loads (good fuel efficiency), and run the batteries (with AC inverters?) for the minor loads during the day (less than 25% generator loads where fuel flows are high, and power used is low).
    Very much like running a "hybrid" car...
    you might have better luck trying to use solar thermal energies to turn the alternator. for that much power this would be large and i think you would need to be very inventive to carry it out.
    There is the STG project.
    Not that I believe that is it anywhere near practical yet (or even working)... But I am not part of the project--so what do I know. :confused:
  • System2
    System2 Posts: 6,290 admin
    Thanks Guys for the quick response. I very much appreciate this
    Skip the motor and alternator. Use a good quality Inverter. Invest in a source for distilled water which the batteries need, using well water or river water will destroy the batteries.
    Build a 48V system, which will have less losses than a 12V system.
    Parallel batteries in a 12V system often have imbalance problems which can ruin batteries early.
    obtain a 48v - 12v converter to power 12v items separately, do NOT tap into a 12v battery from a 48V bank, you will ruin that battery in a few months.
  • peterako
    peterako Solar Expert Posts: 144 ✭✭
    Bravo Mike that is also my answer
    Plus a wind generator local made.
    The only correct setup is solar panel charger to Battery to inverter. combine this whit a diesel generator ( old lister or indian listeriod ) or wind generator.
    p.s. in affrica put the battery's under ground away from the heat.
    Greetings from Greece
  • cshoko
    cshoko Registered Users Posts: 2
    Hello,
    Did you get this setup to work. i am thinking of building the same Solar generator as a college project.
    Regards
    cshoko
    Alternative Energy Enthusiast, Harare, Zimbabwe
  • 706jim
    706jim Solar Expert Posts: 526 ✭✭✭✭
    The idea is not great. Lots of complexity with little or no benefit to just going direct solar to batteries. And run the diesel when (and only when) needed.
    When I was young I thought "why not get a model engine, gear it down and then gear it up to get more power?"
    Sadly that doesn't work in the real world.
  • cshoko
    Like i said its a school project and i would like to take the challenge and see the inefficiencies and losses. My setup will be like this:
    Panels-> Charger Controller -> Batteries -> 24V/48V BLDC Motor with a Speed Controller -> Flywheel to add some kinetic Energy -> 220V Low RPM Permanent Magnet AC Alternator
    edited March 2019 #12
    As long as you have someone kick the flywheel (like a potters wheel) you will be assured of some harvest. Otherwise, losses along the way will eat much of your power.
