Xantrex Freedom 1800 HF?
arkieoscar
Solar Expert Posts: 101 ✭✭
I'm thinking of using a couple of these on two separate standby systems. Anyone know of any issues with these? They won't be heavily load (if I can help it) but they need to be working when needed. Thanks for any help with this.
Re: Xantrex Freedom 1800 HF?
Are these mod-sine or pure sine wave inverters. Link ?
What are the batteries?
Recharged with what?
What are you running?Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
According to Xantrex (if I got the correct product) they are MSW inverter/chargers.
As long are you are aware that some (brands unknown) household gadgets die within minutes of being powered by mod-sine inverters. And that brushless motors will run 20% hotter, and draw 20% more power on mod-sine. Weak/defective motors will die quickly, a fridge may last a month before dieing, and some seem just fine.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
