Where do you divert your excess power to?
benthere
Solar Expert Posts: 113 ✭✭✭
From my reading, I see that the Xantrex C60 has a diversion feature whereby excess DC power can be sent to a water or space heater. Presumably other models are similar.
It seems to me that the output to the diversion device is variable in both voltage (predictable) and amperage. What kind of devices do well with that type of power? What types don't? Stuff with controllers, relays, and motors, right? Does that leave anything besides resistance heaters?
I think I also understand that the XW and Outback inverters are designed to "sell" AC power back to the grid which I see as about the same thing for an inverter.
What clever places have you sold or diverted your excess power to in an off-grid application?
Is there any reason a person should or shouldn't do this? What if the dump device fails or is not on? No problem for PV, right? Potential problem for wind generator, as it then has no brake, right?
Thanks.
Thanks.
Re: Where do you divert your excess power to?
The major drawback to a dump based charge controller is that, as you say, your load is probably larger than your array/wind generator. So, you end up discharging the battery, controller "turns off", battery recharges, and controller turns back on...
Lots of "little" cycles probably are not best for the life of the battery and not an optimum battery charging algorithm either.
If you have grid power--than Grid Tied Inverter where you feed back to the grid is the way to go.
There was one post here where somebody (IIRC) had a boat, and their desalination unit was the dump load.
PS: For wind turbines--if you follow the NEC (US National Electric Code) and the turbine requires a dump load--then you should install two--one as a backup if the first where to fail. Protects both the batteries and the turbine from dangerous failures (turbine self-destruct or battery overheat/melt down).Near San Francisco California: 3.5kWatt Grid Tied Solar power system+small backup genset -
My application will be off grid.
I expected the charge controller to be capable of only sending the unneeded input rather than taking the batteries down. -
Re: Where do you divert your excess power to?My application will be off grid.
If the PWM switching frequency is high enough, the little ONs and OFFs will filter out to cause the battery voltage to be relatively constant... Instead of being ON for seconds, bringing the battery voltage obviously down, and then OFF for seconds, letting it charge back up again.. That certainly would not be good for the battery.
This is why these types of controllers (C40, Morningstar, etc) work OK. They switch faster than the time constants of the batteries and capacitors storing and releasing energy in the circuit.
boB -
Benthere,From my reading, I see that the Xantrex C60 has a diversion feature whereby excess DC power can be sent to a water or space heater. Presumably other models are similar.
One exception is the OutBack FLEXmax controller, which can be simultaneously operated as a solar charge controller and as a diversion controller using the AUX feature's "Diversion SSR" mode. Please see this link for additional information: http://www.outbackpower.com/forum/viewtopic.php?f=29&t=2865It seems to me that the output to the diversion device is variable in both voltage (predictable) and amperage. What kind of devices do well with that type of power? What types don't? Stuff with controllers, relays, and motors, right? Does that leave anything besides resistance heaters?
See page 34 in the User Manual: http://www.outbackpower.com/pdf/manuals/flexmax.pdfI think I also understand that the XW and Outback inverters are designed to "sell" AC power back to the grid which I see as about the same thing for an inverter.
You may find this off-grid application brochure to use useful: http://www.outbackpower.com/pdf/brochures/Off_Grid_Power_Solutions.pdfIs there any reason a person should or shouldn't do this? What if the dump device fails or is not on? No problem for PV, right? Potential problem for wind generator, as it then has no brake, right?
My application will be off grid.I expected the charge controller to be capable of only sending the unneeded input rather than taking the batteries down.
HTH,
Jim / crewzer -
As I have alluded to on another thread,, I am going to try to power the 120vac element of my propane fridge from the load control side of the controller.
T -
1) Phaser banks
2) Shields
3) Photon torpedos
4) uphill water tank, for emgerency use, like the Big Creek hydro electric project
http://www.sierrapacktrip.com/bigcreek.htmPowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
How 'bout an uphill laser photon torpedo tank shield?
Tony -
HEY!
Don't make us go all "moderator" on your behinds!
I have a fan and water pump setup as a DIY geothermal cooling. This cools two room during the summer. -
I've been thinking about this for some time. If the day ever comes that I get enough panels on the roof to off-set my wife's ever-increasing energy demands ...:p
The Outback MX60 has an 'auxiliary' function that can trigger a small relay under a number of different programmable circumstances. So my questions for those who divert excess power is: how exactly are you doing it? Sending the PV voltage off? Cutting in a load on the battery side? Or tripping an AC switch to the inverter? That and what criteria do you use to divert? Float voltage seems the obvious choice.
We need to practice up our wiring diagram drawing abilities for more lucid posts!:p -
Cariboocoot,
You may find this related post to be of interest: http://www.outbackpower.com/forum/viewtopic.php?f=29&t=2865
:cool:
Enjoy!
Jim / crewzer -
Crewzer;
That is really valuable! I'm always glad when someone else does all the preliminary work and I can benefit from their experience. Even if it does give me more ideas.
'Coot -
Re: Where do you divert your excess power to?Cariboocoot wrote: »I've been thinking about this for some time. If the day ever comes that I get enough panels on the roof to off-set my wife's ever-increasing energy demands ...:p
I use my Morningstar Relay Driver, which is actually a Voltage Controlled Switch. When connected to a suitable relay, it is programmed to connect another load ONLY AFTER my primary battery bank is fully charged. The disconnect voltage is much lower than the connect voltage, eliminating the possibility of rapid on and off cycles.
My primary goal is to see that a secondary battery bank remains fully charged.
John
John -
Re: Where do you divert your excess power to?As I have alluded to on another thread,, I am going to try to power the 120vac element of my propane fridge from the load control side of the controller.
T
I hope you got this to work and would love to hear how you're going to do it. -
Re: Where do you divert your excess power to?If the PWM switching frequency is high enough, the little ONs and OFFs will filter out to cause the battery voltage to be relatively constant... Instead of being ON for seconds, bringing the battery voltage obviously down, and then OFF for seconds, letting it charge back up again.. That certainly would not be good for the battery.
boB
Would love input. Want the right dc heating element for my currently ac only dometic rm2810 refer. Or do I use the built in ac heater element with an inverter? How exactly this done (relays and such) with the bluesky 3024duo .. am still wrapping my head around this.
- 228 Forum & Website
- 618 Discussion Forums/Café
