Down Conversion By MPPT
bajasurfer
Solar Expert Posts: 30 ✭✭
?Question?
When 35.4V @ 9.90 Amps from 2 panels is down converted by the Outback for the 12V battery bank, what amps will the battery bank see? How about 35.4V @ 19.80 Amps from 4 panels?
Off-grid system
350W PV initially, ultimately 700W PV.
12V Wet Cell battery bank @ 216 A/hrs initially, ultimately replaced with 12V AGM battery bank @ 424 A/hrs.
note: Existing 100% 12V lighting means 24V battery bank not an option.
350W PV
Two panels of following spec:
Max Power (Pmax)* 175 Watts
Tolerance of Pmax +10%/-5%
Open Circuit Voltage (Voc) 44.4 V
Max Power Voltage (Vpm) 35.4 V
Short Circuit Current (Isc) 5.40 A
Max Power Current (Ipm) 4.95 A
SCC
Outback Power FM60 MPPT
Battery bank [Initial]
2 x 12V 108 A/Hr = 216 A/Hr total
Wiring one way
Panel MCs to Bus Bars: 12AWG x 6'
Bus Bars to SCC: 4AWG x 8'
Usage- 3-4 times per month
DoD ~29% [on 216 A/hr batt bank]
DoD ~31% [on 424 A/hr batt bank]
6.0 to 6.5 hrs [per San Diego WBAN #23188 chart]
Have 3500W generator & Vector 30A charger on hand.
Thank you for your time,
Larry A
Off-grid system
350W PV
SCC
Wiring one way
Larry A
Re: Down Conversion By MPPT
Easiest way is to convert to watts: 300W in = 300W out (- losses)
So if you have 350W in (35.4V @ 9.90 Amps )
you get 340W out , at 16V = 21A
V x A = WPowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: Down Conversion By MPPTEasiest way is to convert to watts: 300W in = 300W out (- losses)
V x A = W
So, to get a real-world # with the Outback, would I then calculate actual Amperage using the efficiency rating of the unit? Or would that remain a ballpark figure?
Thanks, again. -
Your panel numbers will be derated as well , both for temperature and isonolation and angle error.
If your in a hot climate, you give up 10-20% for voltage and figure about 950 watt-meter-sq ( panels are spec'ed for 1000 watt-meter-sq )
So peak-rated power of the panels * peak sunshine ( 0.95 ) * Sun-Angle ( 0.90 ) * ( temperature ( 0.90 ) * charge controller efficiency ( 0.92 for 12V operation )
Given your stated figures
350W * 0.95 * 0.9 * 0.9 * 0.92 = 248 peak DC watts into the battery
If Battery is ~13V, 248watt / 13V = 19 amps peak @ solar noon
- 231 Forum & Website
