Solar Ideas for Iridium Recharger Panels
joe_danielewicz@msn.com
Registered Users Posts: 6 ✭
I'd like some ideas on how I can use four Iridium phone solar charger panels #SPN4567A. Here's how each is rated:
Peak Voltage: 3.34 volts
Peak Current: 2.97 Amps
Peak Power: 9.9 Watts
I have four of these and I was thinking of using them to charge a 12 volt battery and power a small LED underwater pool light (see earlier Thread). Now I realize this might not be enough power.
Can you guys give me some ideas for an appropriate solar project around the home? I live in Phoenix AZ so we get a lot of sun. I realize these were designed to recharge a cell phone battery so I don't expect much. Still, if I can figure how to wire them in series and find a cheap controller I should be able to find a good use for them.
Thanks in advance.
Joe
Thanks in advance.
Joe
Re: Solar Ideas for Iridium Recharger Panels
you need to show the link to the post or thread that you refer to for the courtesy of those that you wish to have help by reading it.
on the matter of those small panels charging a 12v battery, i think you may have some trouble with it in doing that as i belive it may not have high enough voltages to do so. now if you can design around a 6v battery the voltages will handle it, but you would not have the ease of buying a controller for that voltage. most 12v pvs will have an open circuit voltage at 20+v and operating voltages at around 17v so if you could get more of those to place in series to come up with an appropriate voltage configuration, then.you can address such things as the battery capacity and what controller and if it can run your led for the lengths of time you need. -
Get a couple of 5W, WV solar dashboard chargers?Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
wv? is that west virginia or did you goof and mean vw, as in volkswagon? hmm, that makes me think that they could coin an ev from them to be a voltswagon. -
WV : volkswagon dashboard battery charger
They all have them on the dashboard for the trip across the pond. Can often be picked up on fleabay.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
- 654 Solar Water Pumping
- 619 Discussion Forums/Café
