Data Protocols
mike95490
Solar Expert Posts: 9,583 ✭✭✭✭✭
Xantrex has their Xanbus,
Morningstar has something ___ in their new MPPT controller,
Outback uses _____
Midnight uses _____
Will any of these be compatible - is there a standard Alt Energy Buss, or will it stay fragmented and exclusive ?
Outback uses _____
Midnight uses _____
Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048
inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A
NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole |
Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor
(1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: Data Protocols
MorningStar uses ModBus ... which is an open standard.
http://en.wikipedia.org/wiki/Modbus
( I worked at Modicon, in Andover MA in 1979 as a tech ... funny, close to 30 years later I used that protocol they released that year 79' for SC-View )
As far as I know everyone else uses proprietary protocols -
Re: Data Protocols
Xantrex's Xan-Bus is Modbus now.
MidNite Solar is using a Modbus protocol too, which will be open not too long from now.
Magnum uses their own protocol but is documented on their web site.
OutBack uses something else, not open.
I would say, look forward to Modbus being the closest "standard" for any of this R.E. stuff. Not necessarily the best protocol around, but close enough for inverter work.
boB
- 230 Forum & Website
