12volt or 120 lights
                    banjorene
                    Solar Expert Posts: 36 ✭
                    AT this time I am running 2 120 volt 90 watt flood lights for Christmas to light up my home outside they run approx, 5 hours a night.
My question is
I have an inverter that I could use to run the lights off my 12 volt system or I'm thinking of purchaseing two 12 volt 128 led flood lights that the spec says they draw around 1 amp each ( or 12 watts each ).
Or I could just run the lights from grid power.
WHich is the most cost effective way to go ??? The bulbs cost around $18.00 each.
The reason I would go to 12 volt bulbs is because I am thinking of using them has flood lights after the Christmas season.
ANY thoughts ????
Thanks Rene
      My question is
ANY thoughts ????
Thanks Rene
            Re: 12volt or 120 lights
 leds are better, but not everybody likes the results they obtain from them for various reasons. i'd suggest buying 1 led light and try it for yourself. if you don't like it in that application you may find a different application that you like it for so as not to waste your purchase or take the plunge/gamble on both of them. can you provide the link to the particular led in question so that some of our led experts here can comment?
 Found the bulbs on ebay I'm not sure if link will work but I would like to get opinions
 on the LED's
 http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=320241851158&_trksid=p3907.m32&_trkparms=tab%3DWatching
 May want to look over at http://www.candlepowerforums.com/vb/, they tend to use the 3-5 watt cree type LEDs over the T1 LEDs.
 I can tell you that led you have linked to will compare to about a 25w incandescent lamp. To get as much light as a 90w flood you will need about 23w of compact fluorescent ($10) or 23w of LED ($100+)3kw solar PV, 4 LiFePO4 100a, xw 6048, Honda eu2000i, iota DLS-54-13, Tesla 3, Leaf, Volt, 4 ton horizontal geothermal, grid tied - Green Bay, WI
 Thank you that is what I wanted to know.
 Will compact fluorescent work out doors ???
 I'm looking for 12 volt bulbs ( flood ) and maybe some that I don't have to mortgage the farm to purchase.
 Rene
 Opps I maent to say will they work outdoors in COLD WEATHER
 Living in CT temps lately in teens......
 I have a few CFL porch lights on my house that I use all year long. The only downside in the cold is that they take a few minutes to warm up and brighten. I'm assuming flood-type CFLs are the same.
 Yes, just get the floods that are basically a spiral CF inside the glass envelope (keeps the heat in). I use those outside and they all start, even at -20F, they take 5-10 min to get up to full output, but if you’re leaving them on you should be fine. I wouldn't recommend them in motion light floods for that reason.
 I know I have seen 12v versions, but the cost was about 4-5 times that of the stock 120vac CF flood lamps.3kw solar PV, 4 LiFePO4 100a, xw 6048, Honda eu2000i, iota DLS-54-13, Tesla 3, Leaf, Volt, 4 ton horizontal geothermal, grid tied - Green Bay, WI
 Brock, do you have a part # for those lights. I'm having a hard time finding them
 Thanks Rene
 i was hearing somebody once said for out doors you should use incandescent bulbs. are they also a form of CFL's or they are something different, which one is better recommended for outdoors?
 Here is a link
 http://www.1000bulbs.com/Reflector-Floods-CFL/
 for picture purposes, I use mostly the R30 sized lamps, but I have a few of the R40 and Par38 units as well. The Par38's are better suited for bare outside exposure. I got my lights at Menards a local and less expensive version of Home Depot.3kw solar PV, 4 LiFePO4 100a, xw 6048, Honda eu2000i, iota DLS-54-13, Tesla 3, Leaf, Volt, 4 ton horizontal geothermal, grid tied - Green Bay, WI
- 232 Forum & Website
