Wind generator
booboo
Solar Expert Posts: 39 ✭
I am getting ready to install a small grid-tie solar system on my home. 6 or 7 170 watt panels and a PV Powered PVP2000 inverter.
I am intersted in making a DIY windmill generator. More for a hobby unless I can make it productive. I feel I can make a setup for about $100 depending on the motor I get. I am still trying how to figure out what motor is best.
How would I go about hooking the wind generator up to the solar?
At what voltage would the windmill be productive and how much voltage would be too much?
Re: Wind generator
check out www.otherpower.com they are all about do it yourself wind power. i made a 10 ft machine based on there plans and it turned out to be a 1000-1200 watt machine and it produces 200-250 watts in real low winds like 6-7mph -
Re: Wind generatorcheck out www.otherpower.com they are all about do it yourself wind power. i made a 10 ft machine based on there plans and it turned out to be a 1000-1200 watt machine and it produces 200-250 watts in real low winds like 6-7mph
Sorry if this is a stupid question, but how are you measuring your output in watts as opposed to amps? Multipying amps by actual battery voltage while charging or reading watts on a charge controller? -
Re: Wind generator
i am simply multiplying amps by battery voltage
- 621 Discussion Forums/Café
