Xantrex Vesta PDC (power dist center)
westbranch
Solar Expert Posts: 5,183 ✭✭✭✭
I found one of these up for auction, unused, anyone know if the breakers etc are still avail?
manual states made in 2001.
thanks
Eric
thanks
Eric
Re: Xantrex Vesta PDC (power dist center)
Hello,
i have not been active at this forum for awhile.
Are you looking for the breakers that go in the PDC or the Vesta Inverter system? -
If for the PDC, the distribution breakers are Square D QO type, available from home depot or other stores.
The transfer breakers are square D QOU type. The 3-pole, 60 amp breaker may cost over $150.00 at electrical supply houses, I found mine on ebay for $20.00
the 20 amp 2-pole should be about $10.00 on ebay.
Email me for the seller link on ebay if you need the 60 amp breaker
The relay boards may be hard to get from Xantrex
good luck -
I have a couple of old Vesta prototypes in my basement that I use for parts shelves.
boB
(in San Diego today) -
boB, if you are still out there, do you have a relay board for the PDC?
Baringsteve said:boB, if you are still out there, do you have a relay board for the PDC?
If not here you can find boB on the Midnite Solar Forum.2.1 Kw Suntech 175 mono, Classic 200, Trace SW 4024 ( 15 years old but brand new out of sealed factory box Jan. 2015), Bogart Tri-metric, 460 Ah. 24 volt LiFePo4 battery bank. Plenty of Baja Sea of Cortez sunshine.
I could also use a relay PCB with the relays intact, or even with out the relays if I could get the PCB.
- 227 Forum & Website
- 618 Discussion Forums/Café
