Xantrex Vesta PDC (power dist center)
westbranch
I found one of these up for auction, unused, anyone know if the breakers etc are still avail?
manual states made in 2001.
thanks
Eric
  • James
    James Solar Expert Posts: 250 ✭✭
    Re: Xantrex Vesta PDC (power dist center)
    Hello,
    i have not been active at this forum for awhile.
    Are you looking for the breakers that go in the PDC or the Vesta Inverter system?
  • James
    If for the PDC, the distribution breakers are Square D QO type, available from home depot or other stores.
    The transfer breakers are square D QOU type. The 3-pole, 60 amp breaker may cost over $150.00 at electrical supply houses, I found mine on ebay for $20.00
    the 20 amp 2-pole should be about $10.00 on ebay.
    Email me for the seller link on ebay if you need the 60 amp breaker
    The relay boards may be hard to get from Xantrex
    good luck
  • boB
    boB Solar Expert Posts: 1,032 ✭✭✭✭
    I have a couple of old Vesta prototypes in my basement that I use for parts shelves.
    boB :D
    (in San Diego today)
  • Baringsteve
    Baringsteve Registered Users Posts: 1
    boB, if you  are still out there, do you have a relay board for the PDC?
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,172 ✭✭✭✭✭
    If not here you can find boB on the Midnite Solar Forum.
  • James
    I could also use a relay PCB with the relays intact, or even with out the relays if I could get the PCB.
