5 watt solar panel, 14.99 Today only
Solar Guppy
Solar Expert Posts: 1,989 ✭✭✭
One day only, found on a site I look at daily for all types of deals ...
->Removed link as deal is now sold out<- SG
Re: 5 watt solar panel, 14.99 Today only
I saw those, it was funny reading the posting going along with that item. Some get it, some don't.
The panel is 5w at 15v, so you shouldn't need a charge controller for a standard lead acid, BUT there is a good chance it wouldn't put out 15v in direct sun since it would be hot...
For someone just connecting this to a battery and letting it go, not a bad deal. I bought the power squid on the regular woot
3kw solar PV, 4 LiFePO4 100a, xw 6048, Honda eu2000i, iota DLS-54-13, Tesla 3, Leaf, Volt, 4 ton horizontal geothermal, grid tied - Green Bay, WI -
Re: 5 watt solar panel, 14.99 Today onlyI bought the power squid on the regular woot
All hail the mighty Power Calamari !Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
