peak solar hours/day
I'm curious. What is considered the level at which peak solar is measured? In other words, is it anything above 800 wm-2? or above 1000 wm-2?
Just curious since the sun in the Gila peaks at above 1000wm-2 for very brief time, but stays above say 700wm-2 for a few hours.
Re: peak solar hours/day
I think that 1,000 w/m^2 is the "standard" that folks use (anything to maximize output/paper specs.
)... However, you can find charts with other values (800, 600 etc.) listed too...
I have a sample of my daily chart posted here http://www.mike-burgess.org/images/MB_May-3-2007.htm
clouds and all. There is only a short "Peak" time. (about 1 hr) but there are about 3 hours either side of peak, that I consider my PEAK producing time. While i might have the panels running for 12 hours in summer, only 6 of them give appreciable power.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: peak solar hours/dayI have a sample of my daily chart posted here http://www.mike-burgess.org/images/MB_May-3-2007.htm
Mike...
What's the blue line on the chart represent??
JimmyD -
The temperature of the inverter, and you can see a drop when my fan/timer kicks in.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
