Outback Configuration Questions (moved thread)
Hello Folks
When I started to put thought in to the PV system for the big bus I decided to do it as a grid-tie with a battery back up that I would run off of and be able to plug in to my rented barn and feed the meter to keep the cost down. So, I decided on a Outback PS-1 set up with a GVFX3648 inverter and a MX-60 controller but, Outback doesn’t make the PS-1 any more so I started to buy my equipment one piece at a time. At this point I have GVFX3648 inverter and the MX-60. Do you think any of you folks would help me put together a list of the remaining pieces of equipment that I will need to complete my system? I decided that im not going to keep my “HUGE” Rolls batteries in the big bus. I’m going to buy 12/8 volt golf cart batteries for the bus and use the big Rolls batteries in my new little shop building. Those Rolls batteries are 318 Lb’s each so I figure they will be much better sitting firmly on the floor of the shop and the 12/75 Lb’s 8 volt one’s would be much better in the belly of the big blue beast. So if any of you guys could put together a parts list for me I would appreciate it.
Peace along the way
Dennis the bus dweller N.Y.
Peace along the way
Re: Outback Products Education
** maybe a moderator can split this off to a new thread ? **
Qty 12
8Volt batteries ? 96V ?
or
qty 8
12V batteries ? 96V ?
Series, parallel, both?
Hopefully, a series/parallel for a 48V battery bank ? (to match your 48V inverter)
Required:
Inverter
Charge controller
Battery Temperature Sensor
Accurate Voltmeter
Appropriate Fuses/Circuit breakers & Disconnect
Optional
Battery Monitor (totalizer)Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: Outback Configuration Questions (moved thread)
Dennis and Mike,
Hope this works better for you both (thank you Mike for the notice).
Don't forget the Outback MATE, MATE2, or MATE2M & hub - it helps to keep the MX60 & FX3648 talking to each other and is the only way to programme the inverter if you need to make changes. -
Dennis,
I'll follow up with you on both forums on Monday.
Regards,
Jim Goodnight
"crewzer"
Eastern Regional Sales Manager
OutBack Power Systems -
Thanks crewzer, I would like to order the rest of the equipment in the next few of weeks.
Mike, I will be wiring the 12/8 volt batteries for 48 volts.
Peace along the way
Dennis the bus dweller N.Y. -
Dennis,
OK. Looks like an interesting project. You might want to check out the “Sustainable Education” article in Home Power magazine (April/May, 2007; issue #118 ), which describes a bus conversion project.
I don’t believe that I can provide you with a complete detailed parts list for your project. You’ll need to discuss specifics with your supplier(s). Also, I’m not sure that I would use a utility-interactive inverter for this particular application. Let’s discuss that a bit:- OutBack’s “G” inverters don’t work well with generators. So, you might be limited to inverter-type generators from Honda or Yamaha. Our off-grid inverters work with just about any generator available.
- The “G” inverters also don’t include the “neutral / ground” switching contained in our “Mobile” inverters. You’ll need to get some specific application assistance with that topic.
- Depending on where you plan to install the inverter, a sealed inverter model might be a better choice than a vented unit.
- Finally, unless the bus’ alternator is 48 V, you won’t be able to charge the inverter’s 48 V battery bank from the bus’ engine. A 24 V or 12 V inverter may have been a better choice.
In short, here’s what you’ll need:- PV array (“60 V” nominal highly recommended; ~86 Vmp STC)
- PV array mounting fixture for attaching to bus
- PV combiner box and DC rated circuit breakers, including GF breaker (specs will depend on array)
- UL-listed able rated for conditions of use (wet? Hi-temp?)
- (MX60 charge controller)
- DC rated output circuit breaker for charge controller (probably 60 A or 63 A)
- Cable from charge controller to inverter breaker
- (GVFX3648 Inverter)
- BIG DC breaker for inverter (175 A)
- Heavy UL-listed cable (2/0 min; 4/0 preferred) from inverter to breaker and breaker to batteries
- Mounting cabinets and hardware for charge controller, inverter, breakers, etc.
- Surge protector (now required by UL-1741 for G-type inverters)
- AC cabling and conduit
- AC load center and AC breakers
- Connection system (including AC disconnect) from G-inverter “AC IN” to backfeed to barn
- Grounding system
But, I hope this discussion will give you an idea of how to proceed.
Best of luck,
Jim / crewzer
