Need help understanding aspects of batteries
Dear everybody,
Could you help me. I want to find the standard or regulation relate to Deepcycle battery testing, and i want to understand the theory of the deepcycle battery.
Could you help me?
Thank you very much.
Pham Minh Thanh
Ennegy engineer
Vietnam
Could you help me?
Pham Minh Thanh
Ennegy engineer
Vietnam
Re: Need help understanding aspects of batteries
the best test for batteries is the load test. this is when a load of a specific amount for a particular battery is applied for a determined amount of time in which a certain level of voltage has been reached. most batteries are rated for 20hrs with a draw equal to 1/20th of the ah rating for 20hrs. this is to take the battery down to 10.5v which is considered dead or 100% depth of discharge or 0% state of charge. manufacturers may vary on their testing so it is advisable to check with them on how to go about it.
the load test is stressfull to a battery, especially if taken to 100% dod, and many of us opt to check battery condition by the at rest voltage and specific gravity readings along with meters that are capable of roughly calculating the general condition. -
This site may help: http://www.batteryfaq.org/
Regards,
Jim / crewzer
