NASA BM-1 Battery Monitor
shortfatguy
Solar Expert Posts: 42 ✭
Anybody hear of this product from UK?
Link
http://www.nasamarine.com/proddetail.php?prod=BMN-1_Battery&cat=15
Link
Re: NASA BM-1 Battery Monitor
Looks interesting...
I prefer the Trimetric line more - specific to Photovoltaic needs
http://www.windsun.com/ChargeControls/Trimetric_2020.htm -
do you think they might be trying to ride the coat tails of our space agency by making some think our nasa made it?
adding that i don't think i'd have called it a bm-1. can you picture bm-2?
:p -
Perhaps I missed something, but it appears to be a nominal 12 V only device. If so, it's not much use for 24 V or 48 V systems...
Regards,
Jim / crewzer -
Looks to be a very simple battery monitor (from the manual)... I think, if you can swing the Trimetric, Xantrex, or the Pentametric, you will have a much more functional unit.
Find the manuals for each of the major units and read through them and see what will work best for you (the better units have a battery temperature sensor, and other battery factors to tweak to match your battery's performance over time, temperature, voltage and current).
