Cheap square Volt or amp meter?
EAdams
Solar Expert Posts: 34 ✭
I am looking to find a cheap amp or volt meter to let me know how the batteries are. Should I look for a meter or just get a charger that has one integrated into it? Keep in mind my budget is REALLY limited.
Re: Cheap square Volt or amp meter?
A cheap meter may help you kill your batteries, if it is not calibrated well, or gets out of whack easily.
Look at the voltages in the Battery Bible (FAQ)
http://www.windsun.com/Batteries/Battery_FAQ.htm
even being .4V off, will let your batteries sit undercharged, and sulphate them.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
A cheap DMM will get you started (digital multi-meter--I am still using the one I bought for college back 30 years ago).
If you are using flooded cell batteries--then a good Hydrometer + thermometer will be pretty helpful too. Much more accurate than even a good volt/amp meter to determine battery state of charge (and health).
Otherwise, just look for cheap panel meters on the internet/Jameco/Digikey/etc. to measure your current.
If you get a good charge controller--you can get one with digital meters (charge current and voltage) included (and/or can be read with a PC).
In the end, a Battery Monitor is the only tool that will work day to day for to check the overall state of charge of your battery system. But--those are not going to be cheap.
I guess you are trying for a small system to run your landscape... More than likely--you will end up killing your first set of batteries by undercharging/over-discharging. It is very easy to set the system up for summer/9 months of the year, and all goes well--then you hit winter and little sun and lots of load (short days/long nights) and--unless you check the system almost daily (and/or use an alternative charging source)--you will be deficit charging for 3+ months of the year.
Using a 7amp northern Tool charge controller. Just using for lights (3-4 10w cfl or LED) when the power goes off (ice or sow storm, etc). Emergency use only. -
Look at this from Radio Shack:
http://www.radioshack.com/product/index.jsp?productId=2103176&cp=2032058.2032235.2032305&searchSort=TRUE&y=8&x=9&pg=1&s=A-StorePrice-RSK&retainProdsInSession=1&parentPage=family -
Own that one... Bought it last week. Decent multimeter but I was wanting something that is just a guage to mount and add a switch to turn it on/off and give me volt/amps. May just spot check it with my multimeter instead. -
Look on here, they sponsor this board.
http://store.solar-electric.com/didcvome.html
- 228 Forum & Website
- 618 Discussion Forums/Café
