Fuse or Breaker
mwilsonnm
Solar Expert Posts: 26 ✭
Hello,
When installing dc disconnects between the array and controller or the batteries and dc distribution panel does it make any difference (as far as safety is concerned) whether you use a fuse or breaker configuration? Thanks, Mark
Re: Fuse or Breaker
It depends on you access. If easy to access, a replaceable fuse would be OK.
In a rooftop PV string, where PV shorts are RARE, I'd use a fuse. (with anti-oxi grease)
Just my 2 cents worth
Fuse notes - run fuses at 80% or less, of "blow" rating, otherwise, they are subject to random failures.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: Fuse or Breaker
no difference except the breaker is more like a switch that can be flipped back to be reused at a higher price than its fuse counterpart.
as far as accessibility goes it should be within easy reach at all times of the year so fuses/circuit breakers and disconnects should not be going onto a roof that needs ladders or weather cooperation to gain access to it.
