radiant floor heat
Hi:
I'm planning on switching to a tankless propane water heater for my radiant floor heating system, and I was wondering if anyone had experience with this. Any recommendations? Brands that are useful or useless? I have an off the grid 12 volt system with an inverter, so running a unit with an electronic ignition is okay.
Thanks!
Coreyumt
Thanks!
Coreyumt
Re: radiant floor heat
Make sure it is rated for radiant heating, not all of them are. I am thinking of doing the same thing. I have direct radiant baseboard, I need a temp of 160-180, most will not get that that high. If you are doing PEX indirect floor heat, then I think the temps are lower.
Here are some that are:
http://www.takagi-usa.com/ -
Solar Shed
500 gal storage @ 180F
http://www.builditsolar.com/Projects/SpaceHeating/SolarShed/solarshed.htmPowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
The funny thing is when I was looking at tank less heater they are typically less efficient then a good power vented tank. Of course the standby losses are higher for a tank of hot water, but watch those efficiency numbers on the models. I have seen some tank less units in the 70's, not so good.3kw solar PV, 4 LiFePO4 100a, xw 6048, Honda eu2000i, iota DLS-54-13, Tesla 3, Leaf, Volt, 4 ton horizontal geothermal, grid tied - Green Bay, WI -
I have used the Rinaai Continuum a couple of times for radiant and both times it has worked great
