convert from 12 volt to 6 volt
FreeBrrd
Solar Expert Posts: 116 ✭✭✭✭
I feel stupid asking this, but I've forgotten & can't find anything on the internet. I want to use a 6 volt fountain water pump on a 12 volt system. I can't find a tiny 12 volt one, but lots of 6 volt ones.
thanks
thanks
Re: convert from 12 volt to 6 volt
Search for something like this http://www.pacificcable.com/Picture_Page.asp?DataName=901-800, whether this one with 800ma is enough for the pump.
GP -
Now I feel even dumber than I did asking. I've got several of those about.. somewhere. Nice thing about moving, I'm finding all kinds of things.
Thank you. -
I was actually thinking more along the lines of if I put a resistor equal to the resistance of the pump in parallel or if I put a resistor in series. One way should half the voltage and the other should half the current ?? It's been a long time since I did any of that kind of stuff. I really prefer that to using a plug in deal.
found it: http://www.play-hookey.com/dc_theory/voltage_divider.html -
When converting voltages, there will be losses. Using a resistor, you get inaccurate voltage if the load deviates from the original calculation. If you use a LM7805 regulator, it's a smart resistor, but you still waste 50% of your power.
You could use 2, 6V pumps in series, and pump 2x the water.
And then there are Switcher Power supplies, which run 90% efficient, and cost a bit more. They can convert from 1 DC voltage to a different voltagePowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Or get a small inverter and AC pump--the AC pumps may last longer too...
I've got a small inverter & an AC pump. Guess I'll use that. Should just use manual pump
- 224 Forum & Website
- 617 Discussion Forums/Café
