is my math right ?
So i am trying to make sure I am not crazy, or that I understand how this works. if I live in florida and we get 5.5 solar hours per day and I have a 1KWH array ( 5x200 watt Panels) . I would get a daily yield of between 5.5kwh and 4.27 if I factor in .77 % of loss. If I use 4.27 as my daily number then in 30 days I have 127.05kwh of output per month and if power is .13 cents per kw then you have a total savings of $16.52 per month. Is this correct or am I missing something ?
Thanks for any input.
Re: is my math right ?
Jim,
Pretty much correct... You can get pretty accurate numbers by plugging in your data to this link.
To figure out your cost per kWhr, try:
Total Cost of system + maintenance over 20+ years / # of kWhrs per year * 20+ years = $/kWhr
Using 20 or 25 years is about as far as you would want to go out...
That's a good "seat of the pants guess". 5 kwh daily, to offset (I'll take a wild guess of 30KW daily useage) knocking your bill back to 25KW ! $5 a day ! But it will get better if rates go up.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
