Excel PV Program Anyone have?
adas
adas Solar Expert Posts: 136 ✭✭✭✭✭
Aloha: Anyone out there make a excel program to show calculations? ie: input voltage or wattage or hours of sun, panel size, inverter effeciency etc. and get calculations filled in. You know, the fun stuff!!!
thanks
Frank
    BB. Super Moderators, Administrators Posts: 33,740 admin
    Re: Excel PV Program Anyone have?
    The PVWATTS website kind of does 90% of the work... I just use the default 0.77 derating factor for Grid Tied systems and use 0.52 for off grid systems with flooded cell lead acid batteries and 85% efficient inverters...
    Just take 0.77 overall * 0.85 inverter * 0.80 flooded cell batt = 0.52
    You can also output the PVWATTS program in CVS and it will give you 365 days of hour by hour watts/m^2 so you can setup your own detailed spreadsheet.
    A lot of the stuff is basic math (using P=IV, E=IR and variations). Most of the stuff I have posted included formulas for battery sizing, array sizing, load sizing, etc...
    And those were derived from the general requirements and rules of thumb we use around here...
    Many times, it is not worth going for 0.1% accuracy when, in real life--+/- 10% is close enough. And many of the other decisions are Code Related (fusing, wire sizing, conduit fill, etc.) where you pretty much need the NEC or local building code used by your town/county.
    What exactly are you looking to calculate?
  • adas
    "What exactly are you looking to calculate?"
    Everything!!!! I am a bit of a techie so I like to know info on all aspects of the system.
    Frank
  • System2
    System2 Posts: 6,290 admin
    adas wrote: »
    thanks
    Frank
    Check my September 10th, 2007 attachment, it does all that and more.
    Cheers,
    Bad Apple
  • adas
    Aloha, Bad Apple. Got it, looks interesting, thanks
    Frank
    Direct link to that post :
    http://forum.solar-electric.com/showpost.php?p=7941&postcount=11
