Outback Customer Service
Mangas
Solar Expert Posts: 547 ✭✭✭✭
I had the pleasure of calling Outback's customer assistance line today.
On hold less than 20 seconds, immediately linked up with a helpful and knowledgeable tech who answered my questions in language I could understand without making feel technically undernourished (which I am). This kind of first class service builds solar consumerism and product confidence.
Based on the positive experience, they sure will keep my business.
Re: Outback Customer Service
Great to hear good news, especially in these modern times when so many seem fixated on finding something - anything, to complain about.
Thanks for the report
Wayne -
Agree Wayne.
I asked one pretty technical question which I didn't expect an immediate answer but they insisted on running the answer down for me while I was on the phone.
Shows a lot of pride in their product.Ranch Off Grid System & Custom Home: 2 x pair stacked Schneider XW 5548+ Plus inverters (4), 2 x Schneider MPPT 80-600 Charge Controllers, 2 Xanbus AGS Generator Start and Air Extraction System Controllers, 64 Trojan L16 REB 6v 375 AH Flooded Cel Batteries w/Water Miser Caps, 44 x 185 Sharp Solar Panels, Cummins Onan RS20 KW Propane Water Cooled Genset, ICF Custom House Construction, all appliances, Central A/C, 2 x High Efficiency Variable Speed three ton Central A/C 220v compressors, 2 x Propane furnaces, 2 x Variable Speed Air Handlers, 2 x HD WiFi HVAC Zoned System Controllers -
What I like even more about Outback is that I've never had to call them for support. :-) Glad to know that if I need to call them it'll be a pleasant experience.
Cheers,
Bad Apple -
Installed 3 OB systems I new 2 quasi new/secondhand seem to Do What They Say On the Tin........but also add X have been good with me also;)
