Is there a drain on a inverter system?
shortfatguy
shortfatguy Solar Expert Posts: 42
I've been told I have a low-end system.
Q: If a battery bank is fully charged and plugged into a inverter that is plugged into a wired camp, yet there is nothing running or plugged in. Is there a draw on the battery bank?
Cheers.
    Re: Is there a drain on a inverter system?
    An inverter will take somewhere between (roughly) 1 and 6 watts or so--plugged into the DC battery bank, but with no load on the output (some may be more, some may be less).
    Generally, for a small system, you should turn of the DC supply to the inverter (or use the inverter's inhibit switch--if it has one), if you don't expect any loads.
    More advanced (expensive) inverter do have power save modes to "scan" for when loads are applied.
  • icarus
    For example, the Morningstar Suresine 300 draws 55ma (Less than a watt) while in search mode. It also comes with a remote switch system to turn it off.
    Icarus
    No, my inverter is indoors, and does not collect water, so I don't have to have a drain connected.
    Seriously though, as long as the inverter is connected to the battery, and is presenting 120V to the outlets, it is ON and drawing power from the battery. The amount varys with brand/style of inverter, look for "standby" power consumption rating.
  • System2
    System2 Posts: 6,290 admin
    mike90045 wrote: »
    WHAT ??
    Hahahaha That was a good one Mike :p:p
    Had me going there for a few seconds, wondering "what the heck is this guy talking about" Hahaha
    Wayne
  • shortfatguy
    So is there a auto-flow switch that can be plugged into the 120v side and wired back to the 12v side for auto on/off?
    Mw
    Nothing that I know of that you can buy... I saw a very old genset that would put 12 volts DC out the 120 VAC line and when it detected current flow, would autostart. Once the AC flow stopped, it would turn off and apply 12 vdc again and wait.
    Not a separate switch. Some inverters have the function built-in. Sometimes called Sleep, Search, Hibernate. You have to read past the marketing words to find the action the inverter actually takes.
    Here's one example of an inverter that has a very low "idle" (idle means fully powered, and ready to run a 120Vac load)
    http://www.morningstarcorp.com/products/SureSine/index.shtml 300watt run. 600W surge
    Inverter On (no load) 450mA
    Stand-by 55mA
    [requires 8 watt load to "wake up" to full power] (sleep)
    Inverter remote Off 25mA
    [repressed joke answer]
    A regular float switch for a bilge pump will start the drain
    [/repressed joke answer]
  • shortfatguy
    mike90045 wrote: »
    Thanks. Picked up a new coleman 800w for $35 from a friend. It doesn't support "marketing words" so looking for some sort of auto on/off switch
  • icarus
    I assume that the coleman is a generator.
    Beware Coleman's. In my experiance they have very funky voltage control, as well as floating neutrals.
    Icarus
  • shortfatguy
    icarus wrote: »
    Icarus
    No it is a power inverter that was never used. I have a typical house switch and wiring to my 5000w generator starter that I could rewire to be in-line on the 12v side of the inverter, seems like overkill
  • icarus
    I'm a little unclear as to what you are trying to achieve. Are you trying to kill the inverter load when it is not used, or are you looking for a transfer switch from inverter/generator? Or an auto on switch?
    I'm may not be reading it very well, If you are looking for a way to turn the inverter off, why not just use the dc breaker as a switch, or just a switch. If you are looking for a transfer switch from generator to inverter, a double pole, double throw switch will do just fine. (You want to use dc rated switches and breakers if you have any significant current however)
    Icarus
  • shortfatguy
    I'm trying to get the inverter to shut-off automatically without trekking to my generator shed every time I want to use the inverter.
  • icarus
    Then it sounds line you wish to switch the dc side. Relay controlled switch perhaps. One that is energized from the dc side. I suspect that things depend somewhat on how far it is from inverter to the switch location.
    Icarus
