Name and Model of Generator to...
Using my Xantrex SW Plus 2524 inverter to sense low voltage in my battery bank, what make and model generator (5-6K) is available to start and shut-off per the inverter's command? Second, does the generator need an automatic choke? Thank's in advance.
Re: Name and Model of Generator to...
Ah the $20,000 question a smart man will step up to the plate.....but not I....... or you could PX your current system for a PFC inverter charger by Magnum or Xantrex.....stand by for OB to respond very soon !
Am I near the vessel of truth ? -
Re: Name and Model of Generator to...or you could PX your current system for a PFC inverter charger
What does " PX " mean ?Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
