xantrex forums messed up - help
mike95490
Solar Expert Posts: 9,583 ✭✭✭✭✭
I don't know if anyone here (wind-sun) has any working links at the xantrex forums. They did some sort of "upgrade" there, and I can't log in anymore, can't reset my password, or diddly. Let them know I'm not mad at them - I just can't log in.
Mike90045
Mike90045
Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048
inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A
NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole |
Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor
(1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: xantrex forums messed up - help
Cann't register either. Give them time to fix the "downgrade" -
I was able to log on and post but came up with errors although the posts did appear, Ive left the messages of my dificulties -
Mike Ive updated your log on problems and problems with registering, -
Re: xantrex forums messed up - helpMike Ive updated your log on problems and problems with registering,Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
I just gave up and made a new log-in. I hadn't been over there in a while anyway.3kw solar PV, 4 LiFePO4 100a, xw 6048, Honda eu2000i, iota DLS-54-13, Tesla 3, Leaf, Volt, 4 ton horizontal geothermal, grid tied - Green Bay, WI -
They've got things working for me now. Thanks ya'll for the help.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
- 231 Forum & Website
