Beware higher morning voltage
softdown
Solar Expert Posts: 4,083 ✭✭✭✭
6am voltage has been ~ 48.2V due to cloudy afternoons, hot weather and multiple freezers. Was 48.8V until a couple weeks ago.
This mornings voltage was ~ 49.2V so I was pretty happy to see the improvement. Just figured the sky was less cloudy and I used less energy than normal.
Decided to check the new freezer temp alarms I installed yesterday. The largest commercial freezer was at 22F so I started poking around.
Turns out that a power strip somehow died last night. Three freezers were receiving no power. I had a power outage alarm on the outlet but not on the power strip.
Tomorrow's 6am voltage will be “concerning.” Especially given the cloudy conditions this afternoon. Already down to 50.3V at 6:45pm.
The freezer temp alarm is not loud enough and sounds periodically. Perhaps the freezer alarm is what got my dog barking at 4am.
Beware higher morning voltage.
Next am was 47.4V. This am was 47.8V due to afternoon clouds.A few batteries were low on water. Unsure how that affects bank voltage levels.Using a couple more small freezers this year. Inverter cooling fan is running maybe half the time. A lot. I have a back up inverter.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
- 896 Solar Product Reviews & Opinions
